Originally Posted by California98Civic
Yes, if the manifolds are interchangeable that is cool. Check out the wide-band O2 sensors details too. The wide-band sensors are definitely a requirement for the VX/HX lean burn capability. The CX would not have had the wide band sensor. I don't know of substitutes for the costlier versions people on here have seemed to regard as required hardware for lean burn to work properly. Ebay and such might be really poor guides in this area. Search here on EM for the best details. Here's an example: http://ecomodder.com/forum/showthrea...sor-21933.html
No, I don't believe that there's any way of getting around the 5-wire O2 sensor; but the good news is that it may work just as well in a used CX manifold. Frankly, I'm finding more options that way without the frustration and exclusivity of searching for a VX exhaust manifold.
