Old 06-16-2014, 01:10 PM   #19 (permalink)
oil pan 4
I believe you are correct.
The Nitrogen tire testing was more controlled.
The gas mix tire was heated by the sun and aluminum reflector.
My difference between the N2 tire test and the gas mix test was about a half PSI difference between the 2, that difference was likely caused by even heating of the N2 tire versus the uneven heating of the gas mix tire.
The gas mix test scope was to heat the tire up as much as possible from the base line to see if there were any wild pressure swings.
I thought there would be a much wider pressure swing with the R-404a mixture, because of the way refigerants act in a refrigeration system.
