[QUOTE=oil pan 4;430103]
My difference between the N2 tire test and the gas mix test was about a half PSI difference between the 2, that difference was likely caused by even heating of the N2 tire versus the uneven heating of the gas mix tire.
you have a pressure gauge accurate to 0.5 psi and you are using a recorded difference of 0.5 psi as significant data?
so... um... well good luck with the research.
