Old 06-16-2014, 06:25 PM   #9 (permalink)
aerohead
trans/mpg
Originally Posted by BhavyD View Post
Hello. I am a part of a team trying to build a super mileage vehicle(urban concept). We have decided to use the gy6 50cc engine and the vehicle weight is estimated to be around 100kg. What type of transmission should we go for?
Is nuvinci CVP a good option?
Will the vehicle actually be operated on public roads,with all the attendant traffic,idling,acceleration,deceleration,yields,st ops,traffic lights,gridlock,curves,turns,parking,warm re-starts,cold re-starts,etc.?
Is 100 kg you all-up weight,including driver?
For all the transient loads,you'll need to keep the engine in it's peak BSFC island.12-speeds is equivalent to a CVT according to SAE research.
For a steady-state economy cruise you'd want a fully-locked,1:1 output(no overdrive)with a traction tire diameter which would yield the ideal 'gearing.'
Sprocket and chain drive has been used to good effect with some previous record cars.Very high mechanical efficiency.
