Old 06-17-2014, 04:03 PM   #70 (permalink)
backpacker3
backpacker3's Avatar
Homer - '02 Pontiac Sunfire SE
Team Pontiac
90 day: 30.05 mpg (US)
Originally Posted by IsaacCarlson View Post
I have a 2002 sunfire that had the 2.2 and 4t40. The mileage was variable and I was not happy with the amount of torque. I am working on installing a 3800 series 2 with a 4t60 with a 2.84 final drive. I can take the final down to 2.56 with a chain and sprocket combo. I am planning on a solid 40 mpg with the 2.84 final in there. The sunfire is 800+ lbs lighter than the donor car
The engine is in tip top shape, 200 lbs of dry compression and PLENTY of power. I should be able to climb mountains in 4th gear Not sure if I will get it done this year or not, but it is in the shop and is half done.
Sorry to thread jack here but I'm interested in seeing what you get out of the sunfire. I've seen a lot of swaps similar to what you're doing but it's always for the performance so I've wondered what difference in fuel economy is. You should post a build thread.
A bit more on topic though is that we need a team for pontiac. There's one for chevy and saturn but not for us I tried to make one but it was throwing errors at me. Daox do you need to be a mod or something to start a team?
I know what you're talking about for the air dam I don't know know if you're is exactly identical to mine but there's one in the lower radiator opening and then under the radiator is another one I don't really understand the placement of them. I think I might take the one in the lower rad opening out once I put a grille block there.
