Old 06-17-2014, 07:28 PM   #14 (permalink)
83gs1100g
83gs1100g's Avatar
ok if wiki is right than tell me what happens to the valves when it goes into lean burn? wiki says its in 12v mode from idle to 2500. if that were the case then why does it go into lean burn if its already there from idle? it only goes into lean burn when you are crusing(12v mode). all others 16v mode.
