Its a bit clouded on my results on my truck for fuel economy too..Ive accelerated and had it shift at 2500 rpms before and ive had it shift at 3000 rpms before and both at certain times have got me good fuel economy and they have also gotten me bad fuel economy. But i do know at 3000 rpm i use less throttle as opposed to 2500 with more throttle. The torque converter really makes it hard to tell how well i'm managing the power from the engine to the drive line efficiently. So from day to day i constantly find myself always re correcting my rpm shift point habits as well as throttle habits and sometime each of these tactics work for better mpg and then sometimes they wont.
Here are the tactics i used:
shift point: 2500 rpm using small amount of throttle
shift point: 2500 rpm using a lot of throttle
shift point 3000 rpm using small amount of throttle
shift point 3000 rpm using a lot of throttle
And in the mist of this i also try to determine with its just more efficient to accelerate briskly up to speed or as slow as possible. I'm sorry if you heard these debates before but id thought that my situation might have some differences to it than most.
