Old 06-17-2014, 09:56 PM   #15 (permalink)
vrmouseyd15b
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
Originally Posted by 83gs1100g View Post
ok if wiki is right than tell me what happens to the valves when it goes into lean burn? wiki says its in 12v mode from idle to 2500. if that were the case then why does it go into lean burn if its already there from idle? it only goes into lean burn when you are crusing(12v mode). all others 16v mode.
Just like my 3 stage vtec d15b. WHEN IN LEAN BURN, it is in 12v mode, first off.
THINK OF LEAN BURN AS A "GOOD LIMP MODE" - it flutters the injectors rather than spray them
With my old lx tranny, I ran as hard as 3200rpm (about 80 mph) and my econo indicator "happy light" was still on (I run a 37820-p2j-j62 ecu) ON P2J ECU'S THE ECONO LIGHT IS A SWITCHED GROUND FROM PIN A30. YOU BRING POWER TO THE OTHER SIDE OF THE BULB.
With my 3" exhaust cannon, I can hear lean burn switch into 12v mode, 1st and 2nd stages.
Lean burn sounds almost like the injectors are firing only on the positive side of a sine wave, If that makes any sense.
The exhaust sounds "waffled out" but if I push the right pedal, even below 3000rpm (when I hit first stage vtec), the sound changes to a norma lexhaust sound. Then it sounds like my normal motor
