Originally Posted by iveyjh
wiki is right and xntrx is right, works just like my civic HX vtec-e except my HX switches at about 3150 rpm under light load. You can make it run 4 valve 100% by full throttle.
vx lean burn is NOT the same as hx lean burn. so tell me when does the hx go into lean burn?
