Old 06-18-2014, 01:10 AM   #37 (permalink)
ecomodded
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
From what I have read and gleamed it should best to accelerate somewhat quickly , using more engine load / throttle.
My thought on it is you don't have to press the throttle near the floor , instead press it far enough that the truck will use the gas to accelerates with, don't over press it , for little to no result.
keeping the gas flow in sync with the 'pick 'up' of the motor.
Also you are going to want to hit a rpm that induces your gear change, so if you change gears at 2300rpm you'll want make that your goal, and not race on past it.
*Get road tires on rims*, and swap to off road tires when your going off road
Changing to road tires should save at least 5 MPG and would extend their life for years and years. I have to suggest the tire change as it will save you a fair amount of gas..
Save gas
