Old 06-18-2014, 03:41 AM   #5 (permalink)
UltArc
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Kill switch. Even if you are key starting, the time needed to flip the switch is less.
A few people here don't like to use a KS because they have whatever reason, like to stop the IMA from restarting the engine when put in gear- But what I don't understand is this: Using the key off method, one has to keep the key off until the engine dies or it will restart (at least in the Mustang and Insight). If one uses a kill switch, everything runs normally, then flip the switch to ON and then crank over to restart. Instead of 3-6 seconds to kill the engine (depending on RPM at shut off, and engine) one has a half second of turn back, and turn forward.
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
The Following User Says Thank You to UltArc For This Useful Post:
Fat Charlie (06-18-2014)
