Old 06-18-2014, 06:08 PM   #16 (permalink)
aerohead
odometer discrepancy
Originally Posted by nathan01xl View Post
The more I p&g the more error my odometer shows when determining total distance traveled. Fortunately my ultra-gauge is pretty well calibrated (accurate even to radar speeds which show 2x along daily commute) so I don't pay much mind to it. However this last tank i really used p&g a lot and my odometer was showing a really low reading (585 when really went 600).
SO... I decide to check my commute distance via Google maps, and Google is telling me my commute is nearly a full mile longer than I had thought. So that leads to my question...
How do you all verify your route distances?
If you drove your route 'normally',you'd capture what the car system 'sees.' Your speed sensor is not 'transmitting' to the CPU when the power is off,so it's 'blind' during P&G.You could compare that with your GPS.
Since the electronic speed sensor is pulsing with every rotation of your output shaft,I suspect that it has a higher resolution than the GPS.
I don't do P&G and it can be 760-miles between fills,so a small deviation doesn't matter over those distances.
The shorter your route,the higher the potential for discrepancy exists.
