Old 06-20-2014, 08:56 PM   #8 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by master_of_disaster View Post
Another good idea Cobb.
Although, your idea recaptures lost energy from engine idling and not the lost energy from braking.
If you're in gear, it will do both, and have the potential to capture a lot more energy from two wheels with the vehicles weight on them than from a 5th wheel arrangement.
You could possibly run a two stage system one that operates at neutral/idle, and a higher rate during over run/braking.
In a RWD, it would be fairly easy to add a compressor to the axle housing/ driveshaft.
I'd like to know how much energy is lost from compressing air to then reusing it. My daily is a FWD but there was a AWD option, so fitting the rear drive system off a AWD and adding a small motor to drive it all would be pretty simple.
