Old 06-20-2014, 09:05 PM   #195 (permalink)
Bruce_3
More Information...
I should mention that my truck is a 2000 Chevy Silverado 5.3L with the stock cruise module. I tested the speed signal to the cruise, and it was a 12V square wave that was approximately 1 cycle per MPH.
The only wire cut is the speed wire from the PCM to the cruise module. I also tapped into the 'Set/Decel' , 'Resume/Accel', 'Cancel', and cruise power wires.
ID:	15221   Click image for larger version
ID:	15222   Click image for larger version
ID:	15223   Click image for larger version
ID:	15224   Click image for larger version
The Following User Says Thank You to Bruce_3 For This Useful Post:
radiantthought (06-20-2014)
