Old 06-21-2014, 02:19 PM   #1 (permalink)
101Volts
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
How to get the infinite MPG without EOCing in a 2000 Caravan?
I'm aware that I can make the van shut off the fuel injectors when the van is going fast enough (Such as down a steep hill going 35 MPH or faster) and I stick the transmission in Low. How can I make the injectors shut off at a red light, For instance? All that sitting uses up a lot of gas, Otherwise. I tried pulling the fuel injector fuse out with the van on but when I put the fuse back in the injectors didn't turn on again until I turned key off then on, So a fuse kill-switch doesn't work in this case.
The van is the 3-Litre model.
Also, What happens when I see the infinite MPG figure? Are the injectors off then?
