Old 06-21-2014, 05:49 PM   #43 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by Davo53209@yahoo.com View Post
Do you think this aftermarket CAT will achieve the same mpg as an OEM part?
The cat will not affect economy. A/F ratio calculations are based on the upstream O2 sensor and are not affected by the presence or lack of a cat. Does your car have a downstream O2 sensor? If so, this one is only for cat efficiency calculations to determine whether the cat is doing its job or not.
Someone correct me if I am wrong.
