Originally Posted by 101Volts
So what happens if I pull the Engine fuse while the van is idling? Does it turn back on if I put it back in? Can I turn it off and on with a switch in this way?
So you'll get out of your car pop the hood and pull the engine fuse then wait for the light to turn green put the fuse back close the hood get back in the car and then go. But you won't just turn the car off???????????
