Old 06-22-2014, 12:12 AM   #26 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by California98Civic View Post
Suspect the oil filter too. It is on the back of the engine. If it is not tight enough, if the gasket did not seal well because of... something, the oil will leak down the back of the engine. I solved an oil leak by removing the filter during a change and replacing it. Always run a little oil around the gasket with your finger before installing the filter.
Oh yea... I'll check that when I get home. My buddy that I carpool with gave me a gallon of purple power so it gonna use that on my engine. I'll update you guys when I get home from work on the oil filter thing.
