Old 06-22-2014, 12:40 PM   #55 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
The code's been working for a while now. You want to test it?
I remembered that you wanted to be able to measure fuel pressure directly, instead of using an assumed constant value, so as to be able to more accurately measure fuel consumption when you turn off your fuel pump. I built in support for that in the code, but it needs to be tested.
