Old 06-22-2014, 02:45 PM   #22 (permalink)
101Volts
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
Originally Posted by backpacker3 View Post
So you'll get out of your car pop the hood and pull the engine fuse then wait for the light to turn green put the fuse back close the hood get back in the car and then go. But you won't just turn the car off???????????
No, I wasn't very specific. I mean doing this at home just to see what happens.
Originally Posted by California98Civic View Post
If you installed an injector kill switch, you could kill the engine without interrupting any other functions, like radio or fan. When you key back on, you'd get the usual momentary radio drop-out, but then all would return to normal. If you want to avoid multiple uses of the key switch, you could install a push button start alongside the key switch. That way the key could stay unchanged in the "run" position while you cut and restart the engine. But this is really all overkill in an automatic transmission car, because you can't cut the engine in an auto trans car while rolling (EOC, the big FE gains). And since you'd still be using the starter motor. So your best strategy, most cost effective and least expensive with no loss in fuel saving benefits is just to key off and on at lights longer than 10 or 15 seconds.
This works? I'm thinking of doing it at-home to see what happens. I tried pulling the fuel pump fuse and fuel pump relay but those aren't the injectors. My main goal here is to stop fuel from pumping in while keeping the van on, Otherwise (So ScanGauge II info is retained.) The gauge is due for an update in firmware though, At the 4.06 firmware it goes wonky if I shut the van off then turn it back on before the gauge has fully saved the info.
