Old 06-22-2014, 07:25 PM   #29 (permalink)
tvbd56
0.29 Cd and decreasing
Red Rocket - '90 honda CRX HF
Team "Old SKOOL"
90 day: 53.46 mpg (US)
Originally Posted by Old Mechanic View Post
My guess would be distrubutor seal especially if the visible oil trail starts under the distributor which looks like it does from the photo. The crank seal is on the drivers side of the car,where the fan belts are located.
Mech
I second that. My 98 civic was leaking oil, and it would drip off of different places because it dripped off the distributor and trickled to the transmission, engine, oil pan, and even on the plastic undercarriage.
So I believe that could explain your oil leaking from different places. it's pretty easy to do, There's a couple links on youtube of it, and there are 2 seals an inner seal and an outer seal.
regards
The Following User Says Thank You to tvbd56 For This Useful Post:
Baltothewolf (06-23-2014)
