Originally Posted by tvbd56
I second that. My 98 civic was leaking oil, and it would drip off of different places because it dripped off the distributor and trickled to the transmission, engine, oil pan, and even on the plastic undercarriage.
So I believe that could explain your oil leaking from different places. it's pretty easy to do, There's a couple links on youtube of it, and there are 2 seals an inner seal and an outer seal.
regards
Thanks Old mechanic, tvbd, this is exactly the drip pattern of mine, it's completely random where it's dripping off to. If you had seen the underbelly of the car before I washed it, it was literally everywhere, EVERYWHERE.
