Old 06-22-2014, 10:45 PM   #8 (permalink)
Axsle
Axsle's Avatar
Applejack - '01 Honda Civic Ex
90 day: 40.86 mpg (US)
Don't you have to take them off to get to the valve stems?
Yes but there is a gap in the teeth on the inside of the hubcap to make room for the valve stem. So if it rotates then the teeth will either bend it over or cut it.
I'm thinking of trying a layer of duct tape over the teeth next time I check the tires. I know it won't last long but I check the tire pressure every month or two anyway. At least that would be cheaper and easier than that rough grip stuff
