Old 06-23-2014, 06:06 AM   #9 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
There might not be anything wrong. Honda uses alternators with two output levels and an electrical load detector. The ECU will reduce alternator output if there isn't much load on it. On my '91 Civic, any speed above 40 MPH should be 14 volts regardless of load. But I'm usually forcing the alternator into the low output mode.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Cobb (06-23-2014)
