Old 06-23-2014, 09:16 AM   #36 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by Old Mechanic View Post
Hard to tell from the picture but the coolant tubes look to be partially clogged. With your high temperatures you don't want to risk engine damage due to an inadequate cooling system.
regards
Mech
Hi mech, and thanks for the response, however, the car isn't running hot, even when my little bro climbed a 6% grade for ~2 miles in 1st and 2nd gear (stop and go traffic) he said the needle never went above normal temps. I'll get the system flushed and the timing belt/water pump/distributer gasket replaced only then as we originally talked about then. Any other input or ideas on what else I should do? I was thinking about replacing the rad hoses when they do the flush since they are cheap anyway.
