Old 06-23-2014, 02:32 PM   #22 (permalink)
master_of_disaster
Wow! I'm surprised at all the comments that came in over the weekend.
Some very encouraging especially from Old Mechanic about it being implemented before.
Now that somebody has brought up the issue of safety, if ever I do implement this, I probably should just make it a push button type of feature.
When I'm about 1/4 mile away to a stop in a straight smooth road, I can press the pbrake (pneumatic brake) button which will lower the 5th weel/tire. The arm will lower the 5th wheel similar to the rear wheels but be also suspended or have suspension like the rear wheels so the rear weight of the vehicle is evenly distributed between the 2 rear wheels and the fifth wheel. Maybe then the fifth tire will add some lateral stability since its another tire that prevents side to side motion of the rear. The fifth wheel will turn and start driving the compressor to pressurize the air tank. The resistance might be not as smooth so I need to find a way to automatically vary the resistance offered by the compressor either thru electronics or pnuematics.
As I get closer to the stop, I start to use my regular brakes while still pressing the pbrake button until I come to a full stop. I release the pbrake button and the arm goes up.
When I'm about to accelerate, I let go of the regular brake and press the passist (pneumatic assist) button without stepping on gas yet or step on gas and press the passist button at the same time.
This will lower the arm for the fifth wheel and make the air motor drive the fifth wheel and the car forward. This might also need some automatic speed variance via electronics and/or pneumatics.
The air tank will keep running the air motor until the minimum pressure is reached and a light will show that the air tank is depleted and will raise the arm.
Now its back to regular driving.
So the safety precautions will come from making it only active when the driver thinks its pretty benign and not in emergency or uncontrolled situation. There should probably be a max speed cutoff switch.
I plan to put the pbrake button, passist button and air pressure light on the steering wheel just like the volume up and down buttons in newer vehicles.
This project is kinda low on my to do list but if I get more encouraged, and more discouraged with my current job haha, I might really do it.
It really helps to get some negative comments too so I know what I'm up against and find out if this idea is not really viable after all.
