Originally Posted by hat_man
Wouldn't the added down force somewhat hurt FE or are there enough gains to offset the losses?
Another idea I have seen is a front bumper shaped something like this one. Is there a purpose to it being angled back towards the front in the lower half or is it just someone's idea of an interesting design? Would it have a somewhat "splitter-like" effect?
The reason I ask is that I had thought about removing the plastic vertical "air dam" below the front bumper valance and replacing it with a second valance. I would invert it and bolt it together using the existing mounting holes. It's shape would resemble the V shape of the one in the picture but not to the same extremes. It also wouldn't cost $250. I can get a lower valance for about $20 from the pick-n-pull. I saw a picture of the same idea on a red Honda CRX once, but I have no clue where it was.
On the racing trucks,the low dam and splitter help with high speed stability.It also helps their fuel economy in the race.
The jutting splitter helps approximate the jutting nose of a proper half-body as you see in the following image.Anything like it is beneficial as long as its got enough ground clearance for real world driving
