Old 06-23-2014, 09:28 PM   #3 (permalink)
Cobb
The best way to abuse lean burn for mpg is to use it in combination of pulse n glide technique. You use lean burn to extend your coasting once you hit your target speed. In many cases you wont be able to maintain your speed, but if you allow it to bleed off you can and do so til your bottom speed. Now the trick is to combine this in synch with hills, grades, etc.
