Old 06-23-2014, 10:07 PM   #3 (permalink)
Davo53209@yahoo.com
Originally Posted by tvbd56 View Post
Changing the oil pan is pretty straight forward, and it'll be perfect timing with the exhaust off of the car. I think that the oil should be fine to re-use unless the oil pan is degrading particles into the oil.
What I would personally do is when you're refilling the oil, pour it through some sort of filter to be safe.
You know, I had considered the possibility of chunky rust particles degrading from within the pain. The filter idea is a great tip, I'll try that one...Thanks.
