Old 06-24-2014, 10:05 PM   #18 (permalink)
DOFZO
DOFZO's Avatar
SLOMOTO - '92 Honda Civic VX
90 day: 56.49 mpg (US)
Vacuum Gauge Installed!!!
Installed! Idles at 16 in. hg.! Steady!
Although, I'm not quite finished yet. The readings were with the gauge hooked up resting in my hand. Once I had the gauge completely installed in the pod I was only getting 14 in. hg. It didn't make any sense so I pulled the gauge from the pod and found I had crimped the hose between the pod and the a-pillar trim. I need to enlarge the hole in the pillar trim and pull the hose snugly as I install the gauge.
Posted below are a few pics from the install. Thanks to all those who helped in this thread!
Brake booster line with the HELP tee installed.
Pulled an existing firewall plug and pushed a hole through to the interior. The line comes in just to the left and above the clutch cylinder.
Firewall plug drilled out to fit the vacuum hose and retain the OEM plug!
Gauge and pod installed! I sourced an additional A-pillar trim piece for the install. I primed and then painted the lower half of the pillar black then clear coated before installing the pod.
Big Oil hates lean-burn.
Originally Posted by cowmeat View Post
If my hypermiling in the Insight cancels out the effects of just one gap toothed git-er-done in his big dumb F250 dually with his inbred kids and pitbull hanging off the side rails in the back, glaring at me as they roll coal around me . . . . . then maybe there will be some gas left when my grand kids start to drive.
Last edited by DOFZO; 06-24-2014 at 11:00 PM.. Reason: hg. in. to in. hg. and grammar. :(
The Following 2 Users Say Thank You to DOFZO For This Useful Post:
MobilOne (11-06-2015), user removed (06-24-2014)
