Old 06-24-2014, 10:51 PM   #8 (permalink)
DOFZO
DOFZO's Avatar
SLOMOTO - '92 Honda Civic VX
90 day: 56.49 mpg (US)
Originally Posted by 83gs1100g View Post
so at idle its 12v? i disagree. when you accelerate from idle and dont let it get into L/B and you rev past 2500 rpms does the motor gain a sudden increase in power? no it doesn't. then this means vtec it always engaged from idle on and only disengages for L/B.
i dont know how test the 02 sensor to confirm this though. how would you do this? just a volt meter?
If you accelerate from idle what rpm are you shifting at and how "hard" is your acceleration? This isn't a DOHC B18C5, it's a SOHC D15Z1. There is no power!
Originally Posted by DOFZO
Engaging vtec just engages one additional valve per cylinder for a total of 16 valves.
correct.
Vtec-e doesn't engage at low rpm, so how you can agree with this statement and not the other doesn't make any sense.
ZO.
Big Oil hates lean-burn.
Originally Posted by cowmeat View Post
If my hypermiling in the Insight cancels out the effects of just one gap toothed git-er-done in his big dumb F250 dually with his inbred kids and pitbull hanging off the side rails in the back, glaring at me as they roll coal around me . . . . . then maybe there will be some gas left when my grand kids start to drive.
