Originally Posted by DOFZO
Description from the Honda FSM:
The secondary intake CANNOT fully operate until vtec-e engages the secondary intake valve rocker arm...above ~2500 rpm. So at idle, it's a 12 valve engine. Whether or not you FEEL an increase in power. Which, speaking of power, the engine is only capable of 92hp at 5500 rpm. Vtec-e isn't going to put you back in your seat when it engages.
also the posted paragraph is only refering to when its in L/B.
ZO.
i know its not going to through you back but you should feel something??? this is my point. the only time you you feel a kick is when coming out of lean burn. as you stated before the 2500 rpm switchover it is just to keep 12v mode out. so below 2500 when your in L/B and you hit the throttle its going to 16v mode(vtec on) even at idle.
