Thread: My Kamm back
Old 06-25-2014, 12:29 PM   #7 (permalink)
freebeard
What do you guys think about it.. Should it be higher?
Do you plan on changing it? Absent the requested side view, I'd say "Not higher—longer." It appears to be sway-backed, The center could be a few inches higher making a convex curve. Lay a flexible strip on the roof and let it sag to the 12° angle and follow that.
Notice the way Redneck handled the rear wheelwells on his Geo XL1, smoothing over the wheel arch and bumper.
How stiff is the clear material you used (I assume that rectangle on top is clear as well)? If it vibrates, that is unhelpful.
aerohead (06-25-2014)
