Old 06-25-2014, 02:48 PM   #60 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by 83gs1100g View Post
correct. this is what happens. the fuel gets cut back giving better mpg based on being in 12v.
so knowing this is there 3 stages of fuel mapping ie... 12v non-L/B, 12v L/B, and 16v?
cause if i disconnect my o2 sensor and drive as normal it feels as though its in 16v all the time. when i hit the crossover rpm you feel NO increase in power? yes i know its going to be very minimal power increase when this happens! but you should feel something. this is why i question how its described. this is why i question all this? to me its the same process feel if i maintain just barely enough throttle to keep it from L/B when i hit the crossover rpm there is no increase(slight) in power.
thanks all for posting!!!!
12v non-L/B
12v L/B if all parameters are meet
16v non-L/B (there is no 16v L/B)
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
97-civic-ex (06-25-2014)
