I would suspect the vacuum would be slightly lower on a VX since the idle speed is a good bit lower than the average, around 550 RPM. The length of hose was enough to make sure it would cover the distance and routing involved.
My 37 Ford idled at 350 RPM. You checked it by letting it idle in top gear and it was supposed to be 7 MPH!
regards
Mech
