Originally Posted by ecomodded
This piece of advice is useful to me as have thought I could add a "virtual" boat tail by extending the roof only with a void underneath it..
If I ever was to mod my beetle I would cut it down to the desired boat tail shape. My roof is exceptionally high I would cut it down to blend it into the rear hatch similar to the karmann Ghia's roof line.
You can also leave the roof as is,and just add a false K-form structure to slow the contour.
You'd be lofting the curvature up to the 'Template' as VW does with the 1-liter car.And it could be open all inside,with a horizontal shelf extending back kinda like Ernie Rogers did with his 'Bug Wing.'
The whole attachment would effectively be a box cavity.On the passenger side C-Pillar buttress extension you'd want to cut in a window for the new blindspot.
