Old 06-25-2014, 09:51 PM   #13 (permalink)
sarguy01
sarguy01's Avatar
Mazda5 - '12 Mazda 5
90 day: 25.22 mpg (US)
Big D - '11 Dodge Durango Crew
90 day: 18.75 mpg (US)
Originally Posted by spacemanspif View Post
Is the programmer the type with pre-loaded maps or can you make custom ones? For some reason programmers aren't very popular on this site; it could be because they are expensive. Might be able to play with the fuel MAP if you can do custom but make sure you are able to monitor EGT and other critical data so that you don't implode the engine with a bad tune. Water/Meth might also give you a little bit of a boost but can be expensive.
Sorry to tell you, but that truck is HUGE and running around in the city with that big and heavy of a truck is never going to yield good economy unless you shut down a lot but you probably have an auto that isn't P&G with EOC friendly.
Do you do much off-roading? probably not with it being 2wd, a drop kit would help the economy. If you can't figure out a belly pan, consider an air dam (should be plenty of barn doors in TX lol) and side skirts as the next best option.
Programmers aren't popular because they do cost a lot, but also, there is no proof they raise gas mileage. There are other forums with members that swear they got better mileage, but can't provide any testing methods. It's almost as if people guess that the programmer is giving them better mileage.
But, there are some folks that use custom dyno tunes and have had good results. But, a dyno tune and programmer/chip is going to cost what, $600? $1,000? That is a lot of miles to pay back the investment and the gains may not be very good, if there are any gains at all.
