Old 06-26-2014, 12:57 AM   #2 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
The four speed auto on my Mazda Tribute (AKA Ford Escape) was an absolute slush box. The car was great except for the transmission and subsequent awful fuel economy. I attempted a manual TC lockup by simply wiring in a switch to ground the lockup solenoid. The solenoid always had 12V on one side and the ECU switched it on the ground side.
It would work for about 3 seconds, until the ECU realized what was going on and put it onto limp home mode, which required a key switch cycle to reset. I do not know whether it went by an unexpected changed in engine vs turbine speed or if it recognized a problem with the electrical circuit. Either way, I didn't try too hard to get it working properly.
The Following User Says Thank You to mechman600 For This Useful Post:
Daox (06-26-2014)
