i don't think you would feel a difference in braking due to the gauge being run off the brake booster hose. what i wonder is if applying the brakes will cause the gauge to read slightly lower at those moments due to the brake booster diaphragm using most of the vacuum supplied to it. i'm not sure if it would show up or not, just curious.
