Old 06-26-2014, 01:44 PM   #14 (permalink)
redneck
4x8 sheets of 1/2" foam board can be used anywhere structural integrity is not needed. They can be bent and or twisted into nearly any shape desired. Complex, compound curves are possible. Your same belt sander can be used to feather the edges of the foam if needed. You can glue, tape or screw it down with fender washers.
Keep up the good work...
