Old 06-26-2014, 05:40 PM   #37 (permalink)
aerohead
Fig. 7
Originally Posted by ecomodded View Post
I had thought I would leave a little soft curve , perhaps half the size of a the templates depiction , as the boat tail itself would be smaller. I would try to keep it to scale / proportion.
Most designs seem to have the raised portion set at the end of the roof line , I want to move it forward , have it blend off the front of roof instead of the rear.
Figure 7 is actually the profile that I want to do.
Fig. 7 looks sound to me , opinions needed !
(Freebeard I am going to look for your Beetle designs)
The 7th figure from the top is the Koenig-Kamm 'Kamm back' contour and a good choice.
Since the roof would begin at the windshield header it would be significantly lower than the Beetle's original roof peak,and since it is significantly forward of the original max camber position,you're killing two birds with one stone.
It would generate some interesting numbers at the gas pump.
ecomodded (06-26-2014)
