If your muffler was tuned to give power down low in the RPM's I Imagine it would help your mpg , a bit , if you were to use the low RPMs you may save a fair amount.. I am thinking a port and polish with a slightly shaved head to remove restrictions and raise compression a few lbs. Also add a smaller rear sprocket or larger front sprocket to lower the rpm.
Save gas
