See:
http://ecomodder.com/forum/showthrea...ode-27347.html
Fuel heaters have been tested and dont show any improvements on modern engines. Turns out they are pretty good at mixing air and fuel.
Plus if fuel vaporizers work so well, you could test it by using a fuel that is superheated at room temperature, like say propane.
Propane is absolutely 100% vaporized at room temperature at atmospheric pressure and offer no fuel economy improvement.
Most don't do the engine mods too make the best of lpg. Or retune the modern engine.
