I wonder if your nsx has an eld? Its a "honda" right? I think this replacing bats with caps arguement will have a range of results with the vehicles electrical system they go in. I know many hondas turn the alt off and on as needed. Of course the weight reduction should give a little and the less load on the alt as the charge curve should be rather linear vs parabolic as lead acid takes a while to charge.
