Originally Posted by Xist
So, what would painting it white do?
If it was exposed to the Sun it would reflect more heat then it absorbs or much less then Black in any regard , I assume it would radiate less of the intercoollers heat from its surface as well .?
It is strange that "color" can do this , Spooky if you do not understand the science of it & I don't at the moment
could it be color has surface area ?
