Most cheap inverters are not designed to run for 8+ hours at a time and will burn out, you would be better off getting a car charger for your lap top, a lot of lap tops are ~17 volts or so, so you might be able to just power it off a 18v cordless tool battery for about the same cost as a cheap inverter and it would fit in your pocket.
