Old 07-01-2014, 08:38 PM   #15 (permalink)
ecomodded
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
I have my inverter wired directly to the battery where it is fused with one of those car stereo fuses. I think doing it this way gives the inverter plenty of juice to invert.
I am thinking if you run a fused power line from the battery to your inverter it will start charging your big laptop with no problem.
Even being a big gaming laptop its charger should still not use more then 135 - 150w at full tilt boogie.
What you can do is look at the charger and read its output or amperage , times that by the volts & that will give you its max draw in watts.
Save gas
