Old 07-02-2014, 06:04 PM   #98 (permalink)
aerohead
slope
Originally Posted by ecomodded View Post
[ [/url]
In the top left the steeper slope leaves the smallest wake , with the below depiction showing a diagram with a fairly steeply sloped back on it.
Which makes me think the Boxfish *may* be made less steep to accommodate the passenger seating more then being a perfect angle, it may be a compromise, as with the audi A2 slope, I am thinking.
Could be the steeper angle is actually better ? here is a good example of what I am referring to as "perhaps" the better slope.
The SolarWind looks very close to my Beetles shape, I wonder if it's profile is the more efficient one ..?
on a side note:
I just ordered a anemometer gauge better know as a wind meter , for small scale wind tunnel test so I can test with accurate wind speeds.
*Each aft-body,of a particular percentage of total body length will have an optimum slope.This slope will change if plan taper or diffusers are added.
*If the aft-body has 'curvature,' rather than a simple hard angle,the whole process begins again,for each aft-body length.
*No aft-body slope can exceed 22-23-degrees or risk losing flow attachment.You may have the appearance of attached flow on the centerline,but you'll have attached longitudinal vortices produced which have high drag.
*The boxfish roof contour is ideal.
*Here's your Beetle
Here's the SolarWorld GT,it's roof is not ideal (It's a solar array)
Here's Cambridge University's CUER,with Cd 0.10 vs 0.137 for Solar GT
Here is PAC CAR II,Cd 0.075.
It is scientifically impossible to get low drag with steeper angles without artificial boundary layer control devices.
The 'Aerodynamic Streamlining Template' is a scientific contour which was proved in the wind tunnel.There is nothing arbitrary about it.And there is no scientific evidence in the public domain in the last 92-years which suggests that we can beat it in any appreciable way.And that includes 'laminar' forms.
ecomodded (07-02-2014)
