Originally Posted by bennelson
The front lip ground spoiler is pretty low. It's gotta be about 4 inches off the ground. Perhaps the GM engineers were thinking more about keeping air out from under the car in the first place than making the bottom aerodynamic.
I'm sure lots of Volt owners are going to scrape that front lip a bit on speed bumps and steep driveways.
not to advocate smaller air dams, but if anyone was frustrated with damaged volt airdams, i figured this is an alternative to someone possibly completely removing thiers
A shorter front bumper fascia air deflector (part number 20993998) with a higher ground clearance is now available for service. The shorter air deflector brings the ground clearance up to 125 mm (4.9 in) from the original clearance of 95 mm (3.7 in).
