Old 07-04-2014, 01:52 PM   #125 (permalink)
Ironside
Well it is possible to bypass the AC light output and draw the lighting circuit from the battery , all charge goingto the battery then a regulator to run the lights DC and thus LEDs are possible. It will probably run $300 with a bit of change .
I'm aleady running dc lighting, you can do it a lot cheaper than that. You will find guides on the c90 board.
The Following User Says Thank You to Ironside For This Useful Post:
PeterS (07-05-2014)
